AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
P3D 2013 Service Pack 2 soon in French ?
6 REPLIES 6
SamScopeo
634 Views, 6 Replies
or 2014 to be install and 2013 forgeted ?
6 REPLIES 6
in reply to: SamScopeo
Yes, why isn't it possible to install SP2 on French version of Plant 3D 2013 as shown on screenshot attached ?
The readme says (http://images.autodesk.com/adsk/files/autocad_plant_3d_2013_and_autocad_pnid_2013_sp2_en.htm) :
You can apply this Service Pack to the following Autodesk products running on all supported operating systems and languages. Be sure to install the correct Service Pack for your software.
Help ! Need this SP ASAP !
Bernd.Gerstenberger
I can confirm this issue with other languages than English. Currently you can only install this SP2 for the English version. I have logged this issue to our development department.
Regards
Bernd G.
Senior Product Support Specialist
Hi Bernd
Thanks a lot for your answer which save my time 😉
Sam
Hi all,
I had bad news from Autodesk Support Service about SP2 in French for Plant 3D 2013 : the technician said to me : "I am unsure if or when a service pack may be available."
We have so many problems with isometric generation is Plant 3D 2013 that we need to know is the SP2 wil ever exist in French and hope it corrects the problems or if you should migrate our project asap to Plant 2014.
Alexandre
Bernd.Gerstenberger
Hello
I have good news here. The SP2 is now available for all other languages. You can download it here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22092894&linkID=14116968
The noted answer of my colleague was only very carefully.
Bernd G.
Hi Bernd
Thanks a lot again !
”Boost
