AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
P3D 2012 Isometric Dimension Units
6 REPLIES 6
Rcfuss
960 Views, 6 Replies
I am having an Isue when I run an Isometric in 2012.  My units are setup for feet and inches, but anything under 2'-0" reads out in inches.  That is okay for anything from 0" to 12" but I do not want to see 15" I want to see 1'-3".  Anybody have a clue what setting that is?
If I uncheck the "0 Feet" suppression, anything in between 1' and 2' will turn the inches into feet.  So 15 inches will become 15feet.
See attached for example of the iso and for how my units are currently set in the iso.dwt.
6 REPLIES 6
thebearjed
in reply to: Rcfuss
I have the same issue. anything 12" and up should change over to feet and inches (1'-0"). any solutions???
Rcfuss
in reply to: thebearjed
Usually someone would have replied back by now but I haven't seen any responses to this.  I am starting to wonder if there might be something more than an easy fix.
thebearjed
in reply to: Rcfuss
i have posted quite a few questions and its pretty much hit and miss with getting answers, espically in a timely manner.
karthik.nathan
in reply to: Rcfuss
If you open up the IsoConfig.xml file that is being used to generate your isos, and search for 'ImperialDimensionInchCutoff', the default value for that is 24. This specifies the value, in inches, including and below which will be displayed in inches. Changing this value to 12 should dimension anything bigger than 1 foot in feet and inches.
Unfortunately, this setting is not exposed in the UI. Hope this helps.
-karthik
jenakap1
in reply to: Rcfuss
Autodesk was closed last week for our annual week of rest.  So, responses may have been slow during that period.  Thanks.
Pat Jenakanandhini
Product Manager
Plant Solutions - AEC
Rcfuss
in reply to: karthik.nathan
Thank you for the help.
”Boost
