AutoCAD Plant 3D General
Active Member
Message 11 of 19 (382 Views)
Re: P3D 2012 ISOMETRICS
09-29-2011 07:31 PM in reply to: kylepope
Thank you Kyle, the snapshot helps.
Karthik is away for couple of days, hence jumping in. Engine does not scale up the fittings and components (it uses the scale specified by the user). The reason why control station (marked in yellow below) is not spaced-out is because there are no pipes that can be geometrically stretched. All the components are connected to the fittings, hence the result. I would like to discuss this more with you, will contact you separately.
-Murali
Message 12 of 19 (379 Views)
09-29-2011 07:41 PM in reply to: sraffe10
Feel free to contact me anytime.
KP
Kyle Pope
Process and Power Specialist
ECAD, Inc
Our Blog
www.pdoteam.com
Distinguished Contributor
Message 13 of 19 (361 Views)
09-30-2011 01:26 PM in reply to: murali.p
I read your thread with interest - wish I had seen it before I spent many hours "playing" with the set-ups. Anyway I still have a couple of set-up issues that I hope somebody can help me with - see attached PDF file.
Thanks in advance
Regards
Gary
Message 14 of 19 (338 Views)
10-03-2011 09:37 AM in reply to: MOLGRAND
On the hatch scale, edit the ISOCONFIG.xml file, goto line 210 (or just do a find on the line of text HatchPatternScale ) and change the value there.
I'll see what I can find on the other problems and let you know.
KP
Kyle Pope
ECAD, Inc
Our Blog
www.pdoteam.com
Valued Contributor
pkw167
Message 15 of 19 (333 Views)
10-03-2011 10:17 AM in reply to: MOLGRAND
The problem with LDT info now showing on lines with multiple ISOs is a known problem with no solutions yet.
this post covered it:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/P3D-2012-Cutting-ISO-LDT-Bug/td-p/3159292
Valued Contributor
pkw167
Message 16 of 19 (329 Views)
10-03-2011 10:18 AM in reply to: MOLGRAND
on my last post, I ment "NOT" showing, not "NOW" showing... stupid edit function on this forum doesn't work
Message 17 of 19 (288 Views)
10-09-2011 03:01 AM in reply to: murali.p
Thanks for your info - what prog do you use to open it up (I have founf the file) - could you clarify please - I think I am missing something somewhere
On the hatch scale, edit the ISOCONFIG.xml file, goto line 210 (or just do a find on the line of text HatchPatternScale ) and change the value -
Gary
Message 18 of 19 (275 Views)
10-10-2011 06:49 AM in reply to: MOLGRAND
I use a product called TotalEdit, it's a free download from www.codertools.com.  You can also open the file up in notepad, but it has no formatting so it can be a little tricky to read.
KP
Kyle Pope
ECAD, Inc
Our Blog
www.pdoteam.com
Message 19 of 19 (248 Views)
10-11-2011 12:35 PM in reply to: murali.p
Thanks that sorted out the hatch scaling a treat - I just need a few other answers on some other posts I did & Iwill be there on the Isos
Regards
Gary
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
