AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
P&ID Title block
14 REPLIES 14
Message 1 of 15
thiagorincon
5372 Views, 14 Replies
P&ID Title block
Hi, i'm starting do use the Autodesk Plant 3D do make P&ID's. I want to change the Title Block default of the diagram for one that my company use. How can I do that? Thanks!
14 REPLIES 14
Message 2 of 15
Go into the Project you are working on, then in Project Manager, right click on the Project, and click Properties.
In the dialog box, on the left hand side, open up P&ID DWG Settings, then click on Paths. This will tell you the Drawing Template file that P&ID uses.
From here, you can use AutoCAD to edit that DWT file, or replace the file with the one you want to use.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
Message 3 of 15
thiagorincon
in reply to: thiagorincon
Thank you for the answer! Another question: I'm editing the equipment blocks in a project inside the AutoCAD P&ID and I'd like to keep these modifications for all the others projects. Is this possible? How can I do that?
Message 4 of 15
When you create a new project, at the first page is a tick box that says "Copy settings from a template project"
Tomislav Golubovic
Message 5 of 15
Thanks for the help!
Message 6 of 15
No problem, please mark this thread as resolved, unless you have any other questions 🙂
Tomislav Golubovic
Message 7 of 15
OK. I have one more question: I need a report of all the types of equipment that are inside the P&I. I mean, in Project Setup I can find a list of all the possible equipments existing in the software, and I want a report in Excell of all these possibilities. Is there any way to do that?
Message 8 of 15
Easy. In the main PID window, at the top ribbon you have Project Manager and then Data Manager. Click on Data Manager and you can export Reports to Excel
Tomislav Golubovic
Message 9 of 15
Now, I'm trying to change the style of the line. I need to create or modify a process line that have some symbols with its. It would be like creating a "flow arrow style" (Line settings), but instead the arrow, I'd need another symbol. Is there how to do that?
Message 10 of 15
Right click on the Project in Project Manager, go to Properties, then expand the section marked "P&ID DWG Settings"
Under that is a section called "PID Class Settings (or to that effect, I'm not on a PC at the moment) and under that is all the settings for each of the elements in a P&ID. When you find the one you want, clicking on "Edit Symbol" does the layer, colors, linetype etc, and then clicking on "Edit Block" edits the actual block.
Tomislav Golubovic
Message 11 of 15
irenecostly
Please I want to ask for something, I need to activate my autodesk plant 3d 2012, but I don't have money, please help me with the codes, I need to learn this package. Thanks
Message 12 of 15
Ok, thanks! Do you know if it's possible to create a interactive table that remain on the P&ID and that have information like the weight or height of all the equipments? In this case, I would create the table and would select the kind of equipment information that I want to show in the table. After, every time that I create a new equipment, its information would appear in the table.
Message 13 of 15
It would be like any other table, but I would take a look at the Equipment Infotag if its easier. You just place these after you place the equipment.
Tomislav Golubovic
Message 14 of 15
Hi. I need to modify the list of "Linetype" in the "Project Manager", but there isn't a option "Edit Block" for "Pipe lines segments" or "Signal lines segments". How can I do that? For the equipments is possible to edit its drawing, but with the line I can't find this option. For example, I want to create a "Linetype" which shows a circle in the middle of the line and, let's say, that I call it "circle1". So, if I select "circle1" for the "linetype" of a "jacketed pipe segment", every time that I create a "jacketed line segment" in the drawing, it will be a line with a circle in the middle. I hope you have understood me.
Message 15 of 15
ybogdanov
It seems free online course of Plant3D. Why you don't contact with any dealer of your zone for realize the course. It's not expensive, in 20 hours you will be expert of AutoCAD P&ID.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
”Boost
