Hi Autodesk Support,
I have an issue in P&ID Change tagging & Number, I have some of type of the valve and I need to change to another type, the changed affected only the type without tagging.
For more clarification refer the attached screen shot file.
Ahmed Helal
|Hi Ahmed,
The valve code is just a simple text string that has been used in the tag so it will need to be manually changed if you substitute the valve symbol.
Dan
