AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
P&ID Error
17 REPLIES 17
Message 1 of 18
cooldici
2472 Views, 17 Replies
P&ID Error
Dear All,
When  I try to add some equipments to a P&ID, Warning appears "this tool is not supported in a non PNID drawing file"
Please check the jpegs attached.
How can I fix this problem? I updated my Plant 3d service pack and everything but nothing changed. Please help me 😞
Satır içi resim 1
Satır içi resim 2
17 REPLIES 17
Message 2 of 18
cooldici
in reply to: cooldici
It is so bad that I am the only one has this problem:(Smiley Sad
Message 3 of 18
ybogdanov
Could you turn to attach your images another time. It's not appear in post.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Message 4 of 18
cooldici
in reply to: ybogdanov
Here you can find the photos attached.
Message 5 of 18
eadkins73
Was this drawing created in Plant3d?  If so, was it created as a P&ID?
Ed Adkins
EA2 Engineering
www.ea2eng.com
Message 6 of 18
cooldici
in reply to: eadkins73
yes and yes. Here You can see what happens step by sted in the attached pdf.
Message 7 of 18
eadkins73
Thanks for the step by step.  I have had this happen to me.  For whatever reason when a drawing is created through the project manager ACAD puts some kind of identifier in the background to tell plant that is a PnID or Ortho or Iso or whatever drawing.  So for example, if you tried to copy an othro drawing to the project in to the models folder you would get an error message.
Having said that, my only guess is that the template you are using for the PnID was actually created in some other folder and the program doesn't recognise it as a PnID.  So try making a new dwg from another template and see if that will let you add the components.  Then you should be able to cut and paste.
Ed
Ed Adkins
EA2 Engineering
www.ea2eng.com
Message 8 of 18
cooldici
It happens to me even if i create a new project. How come it doesnt say that it s a Non PID drawing when i am using a PID template drawing???Adsız.png
Message 9 of 18
ybogdanov
I send you message. I think that it's happen because your path of direction project is too large. Move it to Desktop or create virtual disc in "My PC" of windows...
Yury Bogdanov
Barcelona (Spain)
Message 10 of 18
cooldici
You see how short is the path. And here is the same problemMan Mad
Message 11 of 18
ybogdanov
Reinstall plant3D... Smiley Very Happy
Yury Bogdanov
Barcelona (Spain)
Message 12 of 18
cooldici
I did once:(
Message 13 of 18
Peter_Jansoone
You're working in a project that came with Plant 2012 training manual, but you are using plant 2013. Maybe the project didn(t convert ? Did you try in a complete new project ?
Peter Jansoone
Plant Design software consultant at Arkance Systems Belgium
Message 14 of 18
cooldici
in reply to: Peter_Jansoone
Yes i did. You can see the caps at my post no:7
I did it for 2012 training project and in 2013 for new project. When i open the project which comes after the installation plant3d's project name "SampleProject" , i am sure you know that one(please find in the attachment)  i cannot add ANY equipment too. So bad:(
Message 15 of 18
cooldici
Aren't there anyone can help me please?
Message 16 of 18
cooldici
I solved the problem by myself. you should change your display language to English if you are from Turkey or any other countries who have this problem guys. It happens because of the computer's language settings.
Message 17 of 18
ybogdanov
Thank you for information!
Yury Bogdanov
Barcelona (Spain)
Message 18 of 18
abaydariyev
Hi Cooldici,
I have same problem, too. Did you solve it?What did you do?
”Boost
