AutoCAD Plant 3D General
Active Contributor
Message 1 of 7 (464 Views)
Overview of total pipe length for pump selection
464 Views, 6 Replies
10-23-2012 11:59 PM
Is there a way to make a selection or just point a linenumber and show me the length of the pipe? The purpose of this is to select pumps so we need to know the total length of the pipe including the amount of bends and fittings.
Product Support
Message 2 of 7 (392 Views)
Re: Overview of total pipe length for pump selection
10-31-2012 10:36 AM in reply to: snijdam
Currently it is not possible to get a total length of a pipe run by selecting the entire line number.
I will log an product enhancement request with our development team.
Dan
Dan Scales
Ahmed1081975
Message 3 of 7 (389 Views)
10-31-2012 12:29 PM in reply to: snijdam
I would Like To add also when select the pipe to show also length and coordinate
And level it's very important CadWorx
Programs have these issues
Ahmed Helal
Valued Mentor
Rich.O.3d
Message 4 of 7 (385 Views)
10-31-2012 04:15 PM in reply to: snijdam
generaly preliminary pump selection and line size is done simply with the known approximation of differnece in head (discharge head - feed head) for the pumps duty and an approximation of total length
then once the prelimnary design and routing of the pipe is done, either a pcf is sent to a pipe analyst for an accurate second pass
If these calcs are done manualy, then i create an iso style such as 'pumpcalc' if you force this iso onto one sheet and only show pipe run components (pipe, elbows etc but not supports) this iso will give the full length in the bom and a qty of elbows, valves, orifice plates, etc for pressure loss factors. this iso will also give you the discharge head
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Valued Contributor
phwatso
Message 5 of 7 (348 Views)
11-06-2012 08:39 AM in reply to: snijdam
You can select the required pipe run and then use quickiso to create a parts list of fittings and pipe length, the advanced tab allows you to export the BoM into excel.
Active Contributor
Message 6 of 7 (338 Views)
11-06-2012 11:26 PM in reply to: phwatso
That is not a sloution but a time taking workaround. I would like to see a summary in the data manager for example.
Product Support
Message 7 of 7 (334 Views)
11-07-2012 01:10 AM in reply to: snijdam
The suggestions offered are indeed workarounds and for the time being they are the best option.
The feature enhancement I have logged with our developers is to get a total pipe length from a simple selection of a pipe run.
Dan
Dan Scales
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
