When I try to make a new ortho view, the default box is 1000's of feet in alll dimensions. This is th despite the model only using a 100'x100'x20' space. Any way to get it to stop starting to big?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
The drawing has no x-ref. Going into the drawing template, it tells me 41 layers are being used despite there being nothing I'm able to select.
Best Regards,
Pat Andres
GHD Manila
Is this in metric? There's a defect that we're trying to track down with metric drawings, but it appears to be ok with ft/inch.
Units are imperial. Appears I finally tracked it down. I finally found the object that was throwing it off. I used this as an opportunity to clear out all unnecessary block in the .dwt file. In the end, it turned out to be an item on the GRADE layer that was far larger than it appeared.
