AutoCAD Plant 3D General
Valued Contributor
alvaro.nimasco
Message 1 of 7 (895 Views)
Ortho Offset issue
895 Views, 6 Replies
08-13-2013 08:58 AM
Hi
Ortho creation, a simple structural 3D drawing, with angle bar beams or columns introduced as structural steels (as always) the orthographic drawings are offset from the real 3D solid model, and same for the baseplates. Nothing in the ortho view is exactly as I see on 3D model view. In 2013 only happens with the baseplates but not with steel sections. But in 2014 happens in both cases.
Any fix for this issue, saw other posts related but couldn't find a solution. We migrated a few projects a couple of weeks ago, can't afford going back to 2013.
thanks
Distinguished Contributor
EricNyh
Message 2 of 7 (878 Views)
Re: Ortho Offset issue
08-13-2013 11:55 AM in reply to: alvaro.nimasco
I have the same issue.  Hopefully a fix is on the way.
Valued Contributor
alvaro.nimasco
Message 3 of 7 (817 Views)
08-19-2013 04:51 AM in reply to: EricNyh
Installing Extension 1 solved the issue.
thanks
Arun_Kumar_K
Message 4 of 7 (800 Views)
08-19-2013 10:42 PM in reply to: alvaro.nimasco
Extension-1 addresseed this problem but don't install extension-1 now, you will come across many other different isues. Wait for some more time, Autodesk will hopefully release service pack-1 solving all these issues soon.
Valued Contributor
alvaro.nimasco
Message 5 of 7 (789 Views)
08-20-2013 01:14 AM in reply to: Arun_Kumar_K
Already installed. Now, we can't afford to stop the orthographic drawings and wait for a SP.
SP should have been released time ago.
Valued Contributor
alvaro.nimasco
Message 6 of 7 (646 Views)
09-19-2013 04:04 AM in reply to: Arun_Kumar_K
so, if a user doesn't have subscription up to date (Extenson 1), he can't generate orthographics.
correct ?
what if we don't renew all licenses ?
regards
New Member
w99220
Message 7 of 7 (67 Views)
06-28-2014 08:30 PM in reply to: alvaro.nimasco
I migrated to 2015 and have the same issue.
what about AUTODESK?
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
