AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Ortho Editor and Current view
2 REPLIES 2
JohnHolder
566 Views, 2 Replies
Any else have issues with getting it to actually work?
Normally it defaults to top view.
I've tried setting the UCS with the UCS and VIEW commands then current view - ends up with a default top view
I've tried clicking the view cube and then current view - ends up with a default top view
I've tried clicking the view cube and then UCS and View commands then current view - ends up with a default top view.
but if I do the above, then click on top bottom right left etc and THEN click on current view - *sometimes* it works.
A random chance?! for this to work is incredably annoying.  This isn't a specific drawing issue either. This has been happening
on multiple drawings.
One would think that when you click on current view it will work and use the 'current view'
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
2 REPLIES 2
Mine is not defaulting to the Top View. Here is where mine is defaulting.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Always the top view.
Master Yoda.
”Boost
