On one machine with 2014 Plant3d - Extension 1 when I go to create an ortho the viewport comes up blank. I have double, triple checked to made sure my model was in the boundary area. No luck. I have audited the project, compressed the database, project purged, repaired plant, shut-down, and restarted. I also repaired frameworks 4.5 as I was getting an error on the projects "ortho title block setup".
I have another machine with 2014 Plant3d (No Extension 1) - Creates the orthos like one would hope. But it has generic layers associated with it pipe, centerline, etc.. However when I go to change the setting to "use 3d model layers", it does not remember my settings nor will it allow me to set dim styles, or text styles.
Anybody have an idear of what could possibly be going on?
Solved by dennis. Go to Solution.
Under the Orthos folder, check to make sure you don't have a DWG folder under another DWG folder. There is a few posts on this. There is something broken on the Autocad side for machines that are updated from earlier versions.
I have found that if I use NO template when creating a Project, then the Ortho/DWGs folder is ok to use for the storage point of Orthos. But if I DO use a template, I have to put the storage point for orthos at the Ortho folder and not DWGs. Once the Project is created, I can then change it to DWGs if I want. It is a bug in the creation of the folders Style and Orthocube. I suspect there is something "hardcoded" to look in a certain place.
Dennis - Thanks a million, I went back created a new project (not using a template) it worked just like it should!
Hello all,
It seems with have a similar problem with a project migrated from Plant 3D 2013. Orthographic drawings either doesn't work or works strangely.
I tried dennis proposition but it doesn't work here.
I opened a case at Autodesk Technical Support, here's the description :
Hello, Before migrating our Plant 3D 2013 (SP2) project definitely to Plant 3D 2014 (ext 1), we are doing some migration tests. We have problem with orthographic drawings after migration: impossible to have paper control (“Contrôle papier”), change scale or even view result of the ortho generation. So what we did is open the Plant 3D 2013 project in Plant 3D 2014 to do the migration (no error reported) and then try to create new orthographic drawings : in that case, impossible to have paper control (“Contrôle papier”) or change scale (see attached file 1-migration ortho.png). Attached file 2-migration parameters.png gives the parameters of ortho. When creating project from scratch: everything is fine, see attached file 3-project from scratch ortho.png and 4-project from scratch parameters.png Then we tried something else: create a new project in Plant 3D 2014 from template (template being the migrated project). In that case, impossible to view result of the ortho generation (see attached file 7-project from template migration ortho2.png). Scale control seems to work (see attached file 5-project from template migration ortho.png) Attached file 7-project from template migration ortho2.png gives the parameters of ortho. Some errors also pop up saying that we should report them to Autodesk: see attached file 7-project from template migration error.png. There seems to be a problem with migration from 2013 to 2014. We cannot start a new project from scratch because we need all modified parameters from our Plant 3D 2013 project. What do you suggest? We can send you files if necessary. It is critical and urgent because we have many many problems with Plant 3D 2013 (SP2) ortho generation so we need to migrate to 2014. Thank you
Hope Autodesk will have a quick solution, we have so much pain here with Plant 3D 2013 and ortho drawings ...
Alexandre Devos
We have otho issues here too, with Ext1 we end up with that same message. The solution we found, so far, is to create a new project with no new settings or existings xml, just for ortho generation.
Should be a Service Pack by now
regards
This issue has been identified and submitted to the product development team.
The workaround is removing the "DWGs" entry at the end of the ortho path string inside New Project Setup Wizard when creating a new project from existing.
Thank you,
