AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Ortho Annotate Problem
11 REPLIES 11
Message 1 of 12
1419 Views, 11 Replies
I have just started using plant3d 2014 & with either a migrated project or a newly created project I have the following problem when using ortho annotate : The only option available in ortho annotate is bop, but I want to annotate line size / line number / spec. I Cannot change the default callout in the project setup either.
11 REPLIES 11
Message 2 of 12
bapan_b
See the bellow command prompt.
Command:
Select a component to annotate:
Specify annotation style or [?] <Bottom of Pipe [BOP]>: ?
Enter annotation style(s) to list <*>:*
Style Name
Center of Pipe [COP]
Full Line Number Callout [Size-Line Number Tag-Spec]
Insulation Callout [Insulation Thickness-Type]
Line Number Callout [Line Number Tag]
Nominal Size [Size]
Pipe OD [Outside Diameter]
Piping Coordinate [Position]
Size and Spec Callout [Size-Spec]
Tie-In Point [TP-xxx]
Top of Pipe [TOP]
15 Years Experience in Piping
Message 3 of 12
paragnewe
in reply to: bapan_b
Hello bapan_b,
I am also facing same problem.
Even if i pressed "*"
it doesnot show me list of other annotation styles..
Anyone can help me in this?
-Regards
Prag
Message 4 of 12
bapan_b
in reply to: paragnewe
please check Ortho Annotation Setup under Pipe Run Component in Project Setup.
Message 5 of 12
paragnewe
Thanks  for your reply,
but i have already set those all annotation styles in project setup.
but still it doesnt come into ortho view.
please see attached snap.
-Regards
Prag
Message 6 of 12
paragnewe
no reply?
please help me out from this..!!!
-Regards
Prag
Message 7 of 12
patpat79
Click the pipe or equipment you want to annotate, click right mouse button, and you will see the ortho annotate option, choose the desired anno style you want to use.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Message 8 of 12
paragnewe
in reply to: patpat79
Done...
Thanks Patpat79..!!!
-Regards
Prag
Message 9 of 12
patpat79
Welcome, hope that I've helped you out. ^_^
Best Regards,
Pat Andres
GHD Manila
Message 10 of 12
paragnewe
yes... you have very good  problem solving skills. 🙂
please see my other problem also..
i cannt able to fix those.. 😞
-Regards
Prag
Message 11 of 12
patpat79
are you the one who has bolt extraction problem? the one that produces PH Imperial Stud bolt (place holder) ?? still havent solved that? thanks
Best Regards,
Pat Andres
GHD Manila
Message 12 of 12
paragnewe
yes.. i am the same person.. 🙂
i have some more queries on that... please see that post.!!
http://forums.autodesk.com/t5/AutoCAD-Plant-3D-General/Bolting-Error-in-Iso-Extraction/td-p/5045836
-Regards
Prag
”Boost
