I have just started using plant3d 2014 & with either a migrated project or a newly created project I have the following problem when using ortho annotate : The only option available in ortho annotate is bop, but I want to annotate line size / line number / spec. I Cannot change the default callout in the project setup either.
See the bellow command prompt.
Command:
Select a component to annotate:
Specify annotation style or [?] <Bottom of Pipe [BOP]>: ?
Enter annotation style(s) to list <*>:*
Style Name
Center of Pipe [COP]
Full Line Number Callout [Size-Line Number Tag-Spec]
Insulation Callout [Insulation Thickness-Type]
Line Number Callout [Line Number Tag]
Nominal Size [Size]
Pipe OD [Outside Diameter]
Piping Coordinate [Position]
Size and Spec Callout [Size-Spec]
Tie-In Point [TP-xxx]
Top of Pipe [TOP]
Hello bapan_b,
I am also facing same problem.
Even if i pressed "*"
it doesnot show me list of other annotation styles..
Anyone can help me in this?
Thanks for your reply,
but i have already set those all annotation styles in project setup.
please see attached file .
but still it doesnt come into ortho view.
please see attached snap.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Welcome, hope that I've helped you out. ^_^
Best Regards,
Pat Andres
GHD Manila
yes... you have very good problem solving skills. 🙂
please see my other problem also..
i cannt able to fix those.. 😞
are you the one who has bolt extraction problem? the one that produces PH Imperial Stud bolt (place holder) ?? still havent solved that? thanks
Best Regards,
Pat Andres
GHD Manila
