AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Orphaned fasteners detected Masage
4 REPLIES 4
Ahmed1081975
925 Views, 4 Replies
Dear All,
In the attached file Screen Shot for Massage comming when i opened the file did any one can explain to me what dose
it mean this massage and how i solve
Ahmed Helal
4 REPLIES 4
lopezjo
in reply to: Ahmed1081975
That message was put in to help identify broken connections between objects in different drawings (via xrefs). However, it can come up in other situations when a connection is abormal.
Have you used Iso symbols in the DWG?
Can you try running the PLANTAUDIT command on the DWG?
Jorge Lopez
Software Architect
Autodesk Plant Solutions
Autodesk, Inc.
Ahmed1081975
in reply to: lopezjo
thanks for your repply Regarding your Question
yes
  i did
But no error comming Fixed 0  is there any another Solution
Ahmed Helal
lopezjo
I believe the ISO symbols are triggering the bubble notification. It is a special case connection to the piping fittings that is not well handled by the orphaned connections checker.
I'll log it as a defect for fixing. You may ignore the warning.
Jorge Lopez
Software Architect
Autodesk, Inc.
thebearjed
when will this defect be fixed...it is quite annoying!
”Boost
