Dear All,
In the attached file Screen Shot for Massage comming when i opened the file did any one can explain to me what dose
it mean this massage and how i solve
Ahmed Helal
That message was put in to help identify broken connections between objects in different drawings (via xrefs). However, it can come up in other situations when a connection is abormal.
Have you used Iso symbols in the DWG?
Can you try running the PLANTAUDIT command on the DWG?
thanks for your repply Regarding your Question
yes
i did
But no error comming Fixed 0 is there any another Solution
Ahmed Helal
I believe the ISO symbols are triggering the bubble notification. It is a special case connection to the piping fittings that is not well handled by the orphaned connections checker.
I'll log it as a defect for fixing. You may ignore the warning.
