AutoCAD Plant 3D General
Message 1 of 4 (188 Views)
Accepted Solution
Objects Compatability w/ Vanilla AutoCAD
188 Views, 3 Replies
04-28-2012 03:09 PM
Greetings All,
Currently our pipers are using Bentley for their work but there has always been an issue for us plain vanilla AutoCAD users.  The Bentley Object Enabler allows us to see the work but we cannot edit them (copy, move, delete, etc.) and always have to pass them back to a piper.
We are migrating over to Autoplant 3D in the near future however we're not buying a seat for everbody so the question I have is, are entities created by Autoplant 3D specific to it or can they be edited by someone who is using plain vanilla AutoCAD? Are Bentley Objects in current drawings editable with Autoplant 3D and/or is there some kind of a conversion process?
Keith
Employee
TomislavGolubovic
Message 2 of 4 (184 Views)
Re: Objects Compatability w/ Vanilla AutoCAD
04-28-2012 04:48 PM in reply to: Volk359
AutoCAD users shouldn't be opening the models. You can install Object Enablers so they can see the elements, but ultimately, you can use the EXPORTTOAUTOCAD command on the models and dumb the models down to basic AutoCAD solids.
Plant3D still needs specs and a database to work, so no, AutoCAD users can't (and shouldn't) be editing Plant3D models.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
Employee
Message 3 of 4 (155 Views)
05-01-2012 12:50 PM in reply to: TomislavGolubovic
Tom is right.  You can open P3D models in ACAD even without installing the object enabler.  You will get proxy graphics and wont be able to see any meta data.  If you install the OE, you can see the meta data.  However, to edit the model, you will need P3D.
Pat Jenakanandhini
Product Manager
Plant Solutions - AEC
Message 4 of 4 (147 Views)
05-01-2012 02:46 PM in reply to: Volk359
That gives me the heads up I needed, thanks much.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
