AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
OFFPAGE Connectors problems
2 REPLIES 2
Symo90
297 Views, 2 Replies
I have a problem with offpage connector.
I make a project and I use offpage connector and all works perfectly. Afterwards I insert some drawings of this project in an another project with "copy drawing to Project" and problems begins:
If I want to connect any drawing from or to a new drawings, all works fine (even between two new drawings) but If I try to connect two old drawings it doesn't works.
And I have another question: my offpage connectors are linked via a section number defined in the drawing properties and this number is a part of all my tag. It's normal that the pipeline losts theire reference to this number when i attach an offpage connector?
2 REPLIES 2
KenFauver
in reply to: Symo90
What version of AutoCAD P&ID are you referring to. If using 2012 download the lastest hotfix.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
Symo90
in reply to: KenFauver
I'm using Plant 2013
”Boost
