Is it possible to add objectid (handle) as a plant property? perhaps plantdefinecalcproperties as a expression?
Solved by eric.fox. Go to Solution.
Solved by jabowabo. Go to Solution.
Are you saying you want a new plant 3d property for your components? Please explain further , thanks.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
I don't see any way to do this except through the API. With it you could add a new property column in the datatable then populate it with the objectId. The PnPId / PpObjectId is available in properties but I'm not sure what you're trying to do so I don't know if it would help you. From the API help file:
The P&ID object identifier (PpObjectId, AcPpObjectId) is a combination of the standard ObjectId and the drawing ID. The PpObjectId persists between AutoCAD sessions in the multi-drawing project environment.
I'd be curious why you want to add the ObjectId to the Plant 3D properties when it already is a readily accessible identifier for the object itself.
We have the SQL database and a Access database for each job... The access one exists because it is easy to work with and i dont hear alot of flack from IT about it.. We run clashes,mto's etc. which outputs a .xls for the engineers to work with. Now I need to link up Navisworks Through datatools and having
the object handle in the database would allow me to link to our navisworks files.. if there is a better way id like to hear and if you want to know anything about how i made the mto with reducing sizes lol let me know.
I got it.. datalinks stores it as decimal. Convert dwghandlelow to hexidecimal and there you have it.. Thanks to Mr. Dave Wolfe
