One of our pipe designers has lost a ability to delete nozzles. CTRL + LEFT CLICK highlights the nozzle as it should. Next, when he hits the DELETE button, nothing happens. If I go to my computer I can delete the same nozzle without issue.
I thought maybe his keyboard had gone bad but DELETE works just fine in other programs...
Solved by TRdesigner82. Go to Solution.
In P3D 2014 you can delete a nozzle the following way too:
Select the equipment and click on Edit Nozzle pencil.
Than go to Change Location and click on Remove.
That will be good to know once we update and go to 2014 in the next couple of weeks or so. Still using 2013 for the time being. Just curious as to why he would lose that functionality?
Honestly, I dont know.
But in the 2014 version you can not select the nozzle with the CTRL button anymore.
You will have to use the method I explained.
There was no intentional change to the program in this area.
When I create a new project, a new drawing, and then add a new tank with nozzles, I can select and delete these nozzles with Ctrl-click and the Del key.
There's something peculiar about your drawing or equipment.
We fell into the solution to this while trying to solve a different issue. He had also lost some of his right click menu options. I found out about the PICKFIRST comand. It was set to 0 on his machine so I changed it back to 1 and now all is good. The right click menu options are back and his delete button works again. I don't know how he got it set to 0 but 1 is definetly the option you want...
