AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Note Nominal diameter with ISOS
2 REPLIES 2
emaiolino
668 Views, 2 Replies
I need to delete the note text that appears in the ISOS which contains the "Nominal Diameter" pipe. How can you ensure that this note does not appear? Attached is a picture.
Thank you very much!
regards
Esteban Maiolino
Titular EMBA Proyectos
Sitio web o nombre del blog
Facebook | Twitter | LinkedIn
2 REPLIES 2
dave.wolfe
in reply to: emaiolino
Open the isoconfig.xml for the style you want to use. Using an xml editor (NOT notepad or IE), navigate to Themes > Theme (Default) > AnnotationSchemes> Size PropertyChangeScheme. Typically you can add an Enabled attribute. If that doesn't work, just remove the value in the Filter, and it will never be applied.
I recommend the following programs:
Zip files and extraction: http://www.7-zip.org/
SQLite Databases: http://sqliteexpert.com/download.html
XML Editor: http://www.firstobject.com/dn_editor.htm
Using the Foxe: http://www.pdoteam.com/2012/08/editing-xml-files/
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
emaiolino
in reply to: dave.wolfe
Thank you very much for the reply!
It worked properly with that remained was solved!.
Esteban Maiolino
”Boost
