I need to delete the note text that appears in the ISOS which contains the "Nominal Diameter" pipe. How can you ensure that this note does not appear? Attached is a picture.
Thank you very much!
regards
Solved by dave.wolfe. Go to Solution.
Open the isoconfig.xml for the style you want to use. Using an xml editor (NOT notepad or IE), navigate to Themes > Theme (Default) > AnnotationSchemes> Size PropertyChangeScheme. Typically you can add an Enabled attribute. If that doesn't work, just remove the value in the Filter, and it will never be applied.
I recommend the following programs:
Zip files and extraction: http://www.7-zip.org/
SQLite Databases: http://sqliteexpert.com/download.html
XML Editor: http://www.firstobject.com/dn_editor.htm
Using the Foxe: http://www.pdoteam.com/2012/08/editing-xml-files/
Thank you very much for the reply!
It worked properly with that remained was solved!.
