I have just realised that while routing pipework, the software is not using my elbows which i created. it is inserting elbows, but not ones that i created and they are not from the spec.
How do i tell p3d to use my elbows?
Solved by Attila.Vallyon. Go to Solution.
if there is something wrong with the spec, or the connection settings, it might be using parts from the Placeholder spec, that is in your project.
Can you post your spec here? And which version of P3D are you using?
Or you turend on accidentally the Pipe Bend button?
