Can you turn the NS off so that it does not come in when ISO's are created? BOM takes care of size so I don't want the NS on the drawings.
Yes
Go to IsoConfig.xml and find <PropertyChangeScheme Name="Size" AnnotationStyle="Standard" Format="{0} NS" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="Size" Placement="Along" />
Locate Format=“{0} NS” ,change the value of Format to Format=“ ”.
After modifing ,you will get <PropertyChangeScheme Name="Size" AnnotationStyle="Standard" Format=" " Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="Size" Placement="Along" />
Close and save the IsoConfig.xml, and create isometric again, you will get isometris drawing without NS shown
