AutoCAD Plant 3D Forum
Nominal Size
3 REPLIES 3
KEY_Engineering_Stacy_Coggin
473 Views, 3 Replies
Nominal Size
Can you turn the NS off so that it does not come in when ISO's are created? BOM takes care of size so I don't want the NS on the drawings.
3 REPLIES 3
Yes
Go to IsoConfig.xml and find <PropertyChangeScheme Name="Size" AnnotationStyle="Standard" Format="{0} NS" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="Size" Placement="Along" />
Locate Format=“{0} NS” ,change the value of Format to Format=“ ”.
After modifing ,you will get <PropertyChangeScheme Name="Size" AnnotationStyle="Standard" Format=" " Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="Size" Placement="Along" />
Close and save the IsoConfig.xml, and create isometric again, you will get isometris drawing without NS shown
Thank you!Smiley Happy
Is posible to change it to mm (in default configuration is inch)?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
”Boost
