AutoCAD Plant 3D General
EileenForan
Message 1 of 2 (1,536 Views)
New hot fixes available now
1536 Views, 1 Replies
07-20-2012 08:55 AM
The following two hot fixes are available for the specific languages mentioned below. The hotfixes are released for AutoCAD Plant3D 2013.
AutoCAD Plant 3D 2013 Custom Parts Builder Hotfix
This hotfix applies to AutoCAD Plant 3D 2013. JPN, FRA, CHS, RUS.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20089556&linkID=14116968
Correct a problem that inch value displays with metric unit in the “Custom Parts Builder” palette.
AutoCAD Plant 3D 2013 Plantpipeadd command Hotfix
This hotfix applies to AutoCAD Plant 3D 2013. CHS, DEU, RUS.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=20087000&siteID=123112&linkID=14116968
Correct a problem that the options of the ‘_Plantpipeadd’ command are not responsive in command line.
Eileen
Eileen Foran
Community Program Manager
Autodesk Plant Solutions
Autodesk, Inc.
Active Member
Message 2 of 2 (674 Views)
Re: New hot fixes available now
11-21-2012 09:28 AM in reply to: EileenForan
 just downloaded and installed the "AutoCAD Plant 3D 2013 off-page connector hot-fix.  Then I go to reload a project that I had just been working in.   and now I get the message, "failed to load project file."and nothing shows up.   Can anyone please tell me what I am doing wrong?  Has anyone else had this problem?
tHANKS
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
