AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
New hot fixes available now
1 REPLY 1
EileenForan
1709 Views, 1 Reply
The following two hot fixes are available for the specific languages mentioned below. The hotfixes are released for AutoCAD Plant3D 2013.
AutoCAD Plant 3D 2013 Custom Parts Builder Hotfix
This hotfix applies to AutoCAD Plant 3D 2013. JPN, FRA, CHS, RUS.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20089556&linkID=14116968
Correct a problem that inch value displays with metric unit in the “Custom Parts Builder” palette.
AutoCAD Plant 3D 2013 Plantpipeadd command Hotfix
This hotfix applies to AutoCAD Plant 3D 2013. CHS, DEU, RUS.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=20087000&siteID=123112&linkID=14116968
Correct a problem that the options of the ‘_Plantpipeadd’ command are not responsive in command line.
Eileen
Eileen Foran
Community Program Manager
Autodesk Plant Solutions
1 REPLY 1
dmitzel2003
in reply to: EileenForan
 just downloaded and installed the "AutoCAD Plant 3D 2013 off-page connector hot-fix.  Then I go to reload a project that I had just been working in.   and now I get the message, "failed to load project file."and nothing shows up.   Can anyone please tell me what I am doing wrong?  Has anyone else had this problem?
tHANKS
”Boost
