AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Need Fix for Plate position issue in Ortho
4 REPLIES 4
Arun_Kumar_K
362 Views, 4 Replies
We are facing serious issue in Ortho, as all the plates located below the supports in plant space are showing at different location in ortho view. We are speding more time in manual edition of all these. If there is any solution available now, please let me know.
4 REPLIES 4
aldevos
in reply to: Arun_Kumar_K
Hello Arun Kumar,
We are facing the same problem...The only answer I had from Autodesk Support Service is that we have to recreate manually all plates in our project which doesn't show correctly in orthographic views.
Please see my post there : http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Impossible-to-have-correct-orthographic-views-when-pl...
Autodesk told me that a fix will be available in extension 1 2014 which is planned for this summer and may be a hot fix for 2013 realease, but who can wait !?!?
Alexandre Devos
Arun_Kumar_K
in reply to: aldevos
Thanks for your reply and shared the views. Lets hope the issue will be solved in service pack. Autodesk pls, take this in priority.
Hi Arun,
This issue is being addressed at a high priority by our developers. I will keep you all posted once I have an update around the fix.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Hi Vinod,
I've adressed the problem to Autodesk on May, 13th and since I have no news. When approximately could we expect a hot fix ?
Alexandre
”Boost
