AutoCAD Plant 3D General
Valued Mentor
JohnHolder
Message 1 of 17 (491 Views)
Modeling up custom fittings
491 Views, 16 Replies
04-24-2012 01:54 PM
I am trying to figure out the easiest way create a saddle ( for sch 40 pvc )
I have it modeled up, converted to a block.  the first time I made it into basically a Tee with 3 connection ports (with plantpartconvert ) two horizontal with 0 spacing and the reduction connection port vertically - like a Tee
but when I place it, it cuts the pipe in the center, which I would like to avoid.
it would be basically an Olet but wrapping directly around the pipe.  When creating a block based component
how many ports should an Olet have? and what would the behaviour be attaching to a pipe length?
I've never had any luck using the plant 3d parametric graphics, and I have all the fittings already modeled from when I didn't have P3D.
Just looking for a different perspective on this.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Product Support
jason.drew
Message 2 of 17 (467 Views)
Re: Modeling up custom fittings
04-26-2012 03:26 PM in reply to: JohnHolder
Hi John,
Are you using AutoCAD Plant 3D 2012 or 2013?
Also, are you needing a pipe saddle or a reinforcement pad?
2012 does not support pipe saddles/reinforcement pads (although there might be a way to use a modified olet to place it on a line)
2013 supports reinforcement pads natively:
http://autocad.autodesk.com/?nd=plant2013newfeatures
Jason Drew
Premium Support Specialist
Product Support
Autodesk, Inc.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Valued Mentor
JohnHolder
Message 3 of 17 (465 Views)
04-26-2012 03:32 PM in reply to: JohnHolder
Pipe saddle. As in an bolted on tee
Master Yoda.
Valued Mentor
JohnHolder
Message 4 of 17 (458 Views)
04-27-2012 12:13 PM in reply to: JohnHolder
I see what you mean by reinforcement pad, but can I have that show up as a saddle in the BOM?
http://www.spearsmfg.com/prod_brochures/COS-2-0804_0610_web.pdf
 Also using 2013 now.
Master Yoda.
Valued Mentor
JohnHolder
Message 5 of 17 (449 Views)
04-27-2012 05:27 PM in reply to: JohnHolder
Also - any Ideas why the catalog builder keeps telling me no excel? ( when it is installed )
Master Yoda.
Product Support
jason.drew
Message 6 of 17 (428 Views)
05-04-2012 08:23 AM in reply to: JohnHolder
Hi John,
I'm currently checking into this issue and will let you know what I find out.
Thank you,
Jason Drew
Product Support
Autodesk, Inc.
Product Support
jason.drew
Message 7 of 17 (405 Views)
05-10-2012 07:14 AM in reply to: jason.drew
My first recomendation would be to reinstall Microsoft Office and then see if Plant 3D finds it. I've never ran into an issue where Plant 3D doesn't detect that MS Office is installed.
What version of Office are you using? I believe Office 2003 - 2010 is supported, but I've never tried using older versions.
Thank you,
Jason Drew
Product Support
Autodesk, Inc.
Valued Mentor
JohnHolder
Message 8 of 17 (365 Views)
05-20-2012 12:56 PM in reply to: jason.drew
So to continue,
trying to make a pvc pipe saddle (eg. http://www.spearsmfg.com/prod_brochures/COS-2-0804_0610_web.pdf )
I am using the olet base parameter.
what does the <End Type> need to be for the main pipe run? and for the reduction side I am using PSW.
currently I am just using PSW for both and it seems to work, but the pipe is not "connected"  there is no red line when you select it as with properly connected pipe.
for one of the fittings the connection port properties I have 24 inch for the P1 ( pipe run ) and 12 inch for the P2 ( reduction )
Master Yoda.
Employee
rajsekarpillai
Message 9 of 17 (359 Views)
05-21-2012 02:39 AM in reply to: JohnHolder
We recently posted Spears Sch 40 catalog in Plant Exchange and please have a look.
Split Saddle we don't support in parametric shape.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Autodesk, Inc.
Valued Mentor
JohnHolder
Message 10 of 17 (346 Views)
05-21-2012 10:39 AM in reply to: rajsekarpillai
yes I know but the question was
the split type saddle is irrelevant since olets have 2 connection ports one connects to the main run and one is the split.
I wanted to know what end types both are if I was using parametric design, so I can use the same type for my custom graphics.
Master Yoda.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
