AutoCAD Plant 3D Forum
Mirrored new Iso symbol (with new end type)
5 REPLIES 5
serafin.albiero
1568 Views, 5 Replies
Greetings All !!
Please help! I have a problem with one of my custom iso symbols. I have tried this solution but unsuccess:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Iso-Symbol-Works-Sometimes/m-p/3624432#M7063
I have created a new end type TC for Port 1 (S1), and:
- Port 2 (S2): BV
- Symbol Type: FLANGE
- Symbol SKEY: My mapped skey symbol, aka MNDT
- Component Category: Flange (Welding neck flange)
See images:
New End Type
Symbol Block with FlipY parameter and Flip1 action:
The isometric with mirrored TC Niple symbol, 3D (green box) ok:
What am I doing wrong?
Thanks in advance!
P3D 2013.
PS.: If I change Port 1 (S1) to FL, isometric generates succesfully with no mirrored symbols!
Serafin A. Albiero Jr.
Tags (2)
5 REPLIES 5
Dear Autodesk Supports
I have Issue in isometric symbol new created for more than 2 ports pleas find the attached photos for more clarification
in my issue please it's very urgent
Ahmed Helal
in reply to: serafin.albiero
Did you ever find the solution to the problem? I do have the same problem..
serafin.albiero
Not yet... Unfortunatelly till now we need to flip 2D blocks manually, and no autodesk support or answer about that issue. I hope someone tell us that this annoying behavior is not present on 2014, or at least they are working on a workaround/fix.
Thanks for the quick answer!
Unfortunately I do use the 2014 version..
m_madrzak
try to change Small bore piping.. to the smallest dimension (check attachment) in Title blok and Display
small pipe sometimes makes some issue
Regards
Michał Mądrzak
Plant Specialist
m.madrzak@mat.net.pl
Phone +48 12 252-06-25
Mobile. 693-015-910
”Boost
