AutoCAD Plant 3D General
serafin.albiero
Message 1 of 6 (701 Views)
Mirrored new Iso symbol (with new end type)
701 Views, 5 Replies
09-25-2012 06:30 AM
Greetings All !!
Please help! I have a problem with one of my custom iso symbols. I have tried this solution but unsuccess:
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Iso-Symbol-Works-Sometimes/m-p/3624432#M7063
I have created a new end type TC for Port 1 (S1), and:
- Port 2 (S2): BV
- Symbol Type: FLANGE
- Symbol SKEY: My mapped skey symbol, aka MNDT
- Component Category: Flange (Welding neck flange)
See images:
New End Type
Symbol Block with FlipY parameter and Flip1 action:
The isometric with mirrored TC Niple symbol, 3D (green box) ok:
What am I doing wrong?
Thanks in advance!
P3D 2013.
PS.: If I change Port 1 (S1) to FL, isometric generates succesfully with no mirrored symbols!
Serafin A. Albiero Jr.
Ahmed1081975
Message 2 of 6 (681 Views)
Re: Mirrored new Iso symbol (with new end type)
09-25-2012 10:22 AM in reply to: serafin.albiero
Dear Autodesk Supports
I have Issue in isometric symbol new created for more than 2 ports pleas find the attached photos for more clarification
in my issue please it's very urgent
Ahmed Helal
Active Member
Erik_Halvarsson
Message 3 of 6 (319 Views)
09-23-2013 05:08 AM in reply to: serafin.albiero
Did you ever find the solution to the problem? I do have the same problem..
serafin.albiero
Message 4 of 6 (313 Views)
09-23-2013 05:27 AM in reply to: Erik_Halvarsson
Not yet... Unfortunatelly till now we need to flip 2D blocks manually, and no autodesk support or answer about that issue. I hope someone tell us that this annoying behavior is not present on 2014, or at least they are working on a workaround/fix.
Active Member
Erik_Halvarsson
Message 5 of 6 (299 Views)
09-23-2013 05:56 AM in reply to: serafin.albiero
Thanks for the quick answer!
Unfortunately I do use the 2014 version..
m.madrzak
Message 6 of 6 (265 Views)
09-24-2013 05:52 AM in reply to: Erik_Halvarsson
try to change Small bore piping.. to the smallest dimension (check attachment) in Title blok and Display
small pipe sometimes makes some issue
Regards
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
