Hi, Autodesk experts and power users! How can I measure ("_DIST" command) plant 3D objects (e.g. supports)- they have not any snap points (EndPoints), except the only one in center. Our users strongly need such feature,may be they need additional snap points?
Hi Autodesk Supports,
In the same issue It' required to measuring between pipes and steel supports so how can I measuring pipe ( from face flange to face Example)
Ahmed Helal
Currently you can only look for the support properties to look for the sizes of the support. See here the attached snapshot. In the preview you will see which property shortcut will be used for what.
If you want to add here an enhancement request, please, log it here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Regards
Bernd
Thank you very much, Bernd and thank you, Ahmed!
Of cause, I would like to add a product enhancement request, but unfortunately I can't to do this - there's no Plant 3D Item in products list at the web page Bernd has provided above
I have created an enhancement request for you and also informed the web team to add Plant 3D to the product list for enhancement requests.
Regards
Bernd
Hi Autodesk Support Team,
I am using Plant 3D 2024, not sure if the enhancement requested above has been implemented!!!
Need the Object snaps to measure distances and/or drawing some construction lines etc.
Any help in this regard will be highly appreciated.
Samir.
