AutoCAD Plant 3D Forum
Material List Qty.
6 REPLIES 6
490 Views, 6 Replies
Material List Qty.
Dear Sir,
We are not able to extract Qty. of Pipe Fittings in material list.
Please prvoide procedure for extracting Qty. from 3D model.
Thanks.
Jaymin Patel
6 REPLIES 6
TomislavGolubovic
Which version of Plant?
Do you mean you want the Qty in the Isometric BOM or if you are using 2012, the Report Creator?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
in reply to: TomislavGolubovic
Dear Sir
we are using 2011 plan 3d
Thk. for reply .but i need bom qty. is in excls formet i was export whole Project bom in excle format but we are not able to get qty.
like how many fflanges there
like how many elbowsare there
like how many tees are  there
TomislavGolubovic
In 2011 you can use Data Manager to export the data and then use Pivot Tables to do a count on items.
Tomislav Golubovic
Autodesk, Inc.
Thk. sir
pl tell me how to give line numbers.
TomislavGolubovic
To place a line number on an item, or a selection of items, in the model, select the items you want to give a line number to, then right click and go to Properties. In the properties pallette, there is a section called Line Number. You can assing an existing line number, or assign a new one.
To export those line numbers, there is a list in the Data Manager already called Line Numbers.
Tomislav Golubovic
Autodesk, Inc.
Rcfuss
That sounds very simple to do if you knew how to setup pivot tables to acheive a total.  Are you telling me 2011 Plant 3d is unable to take the line list, show a total NOT a single cut list of each line?  When I export to excel it does put the line # on individual tab which is nice.
I am trying to export a line list that shows a total of each component. Example:
Line # 3-SG-1115-WW
(50) 3" BW Elbows
(500ft) 3" sch40 pipe
(5) 3" 150# Gaskets
I have my spec setup more detailed than this I am just simplifying.
Thank you.
”Boost
