AutoCAD Plant 3D Forum
Lost Isometric DWG
24 REPLIES 24
Message 1 of 25
2484 Views, 24 Replies
Lost Isometric DWG
Hi, when I generate the Isometric view using either Quick Iso or Production Iso they does not appear in their respective folder in the project I have created, but the drawings are created (I searched for they and I found it, but not within the project), I do not know how to add these drawings to the project
24 REPLIES 24
Message 2 of 25
Venkatesan.A
Go to Project Manager -> Project Setup -> Isometrics dwg settings -> Iso Style setup - > Iso style paths.
Setting your desired location here will put all your quick and prod iso in the respective folders you want.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 25
in reply to: Venkatesan.A
Thanks, but I still cannot see the drawings in their respective folder within the project, even I deleted the drawings and redrawn them with the new file path but they does not appear in the project.
Message 4 of 25
AndyDavisCadline
Quick ISO's are not project deliverables; they are not referenced in the project and are not visible in Project Manager - use them only to check configurations etc.
It is only Production Iso's that are visible in Project Manager.
Andy
Andy Davis
Industry Specialist
Cadline Ltd.
Message 5 of 25
in reply to: AndyDavisCadline
Ok thanks Andy, I am going to generate Production Isos and then I will tell you the result
Kind Regards
Javier Zavala
Message 6 of 25
Thanks, it works, the thing is stablish correctly the path of the drawings creation to avoid issues later
Message 7 of 25
Arch_art
My production iso is not showing on Project Manger. What is happening here?
Message 8 of 25
Venkatesan.A
in reply to: Arch_art
Could you give us more information please.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 9 of 25
Arch_art
ok.. I generate quite a lot of production iso.. which supposed to appear in the Project Manager window so I can manage it as proper drawings. But for some reason, it doesn't do this for me in this project. I don't understand why.
Image 1: Project Manager:
Image 2: Production iso drawing folder:
These are the drawings that in the production iso folder:
Please let me know what is these ASAP. otherwise, I will have to change all my title block to suit this condition. Because they are not the project drawings, I can't assign the drawing property. I will have to change all the title block for 70 drawings. This is not fun.
Message 10 of 25
Arch_art
Yes. I am sure I am creating the production iso drawings. And if you look at the second image, the path tell you that is the production iso as well. And I am very sure that is in the project folder.
Look, as I said, I didn't have this problem before. I been testing the models by producting quickiso for checking. It is only when I am going to create the drawings for submition, I can't find them in the project manager. If they can't appear in the project manager, I will have to replace all the title block.
Cheers,
Peggy
Message 11 of 25
Venkatesan.A
Can you check the below things for me?
1. Check whether you are selecting the "correct iso style" while generating the ISO.
2. Can you check the path under project setup->Isometric Drawings settings->Iso styleSetup->Iso Style paths is correct?
3. Open the Iso error log file to see if their is any error/details.
4. Can you try clicking the "Group by line number" and "Group by drawing" this will force and update if any, in the Project manager.
5. When you generate an Iso, keep an eye on the Project Manager tree, it should collapse down when the Isometric Creation Completes and notification shows up down in the notification tray.
Also, take a look at the date stamp on "Iso.dcf" and "IsoPart.xml" out in the root of your project folder. Both of those files should update as soon as the Iso generation is complete.
What I suspect is your ISO files are getting generated under different (wrong) Iso style folder. Let me know after checking this.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 12 of 25
Arch_art
point 1,2. checked there are all right.
point 3. There is no error log file as far as I can see.
point 4, I don't know where is the "group by line number" or "group by drawing".
point 5. In my case, I got notification, but no collapse down.
point 6. "iso.dcf" is not updated, in my case it is around one month old, and "isoPart.xml" file is updated.
The style is right. but I had been modified the style a lot, not sure if this effect anything. I think it shouldn't be. but let me know what you think.
Thanks.
Message 13 of 25
Venkatesan.A
Hi Peggy,
Yes the project which you gave me doesnt show the isos. I am not sure how the dwgs in the ProdIso were generate, but when I cleaned up the ProdIso folder (moved all files) and regenerated all the Iso's and I really dont see there any issue, it works fine the Iso's show up in the project very well. Also my ISO.dcf gets updated as expected.
What I recommend you is to clean up your prodIsos folder and regenerate the ISO's.
Please refer attached pics.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 14 of 25
Venkatesan.A
Peggy,
Can you confirm if this is working for you?
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 15 of 25
Arch_art
Hi, Venkat
It doesn't work for me.
Cheers,
Peggy
Message 16 of 25
Arch_art
Hi, Vanket
I tried to delete the folder as well. It still doesn't work.
In your previous post, you keep indicate that there is other way to do the production iso. (you said:"not sure how you do it." few times.) As far as I understand there is only one way you can create the iso drawings. Which you have shown on the images at your last post. I like to see what is other way if there is any.
Cheers,
Peggy
Message 17 of 25
Dear Arch_Art
Which Version do you use.
I got the same Problem last week. I use 2012 at the Moment.
My solution was to eleminate all BAD Types, like .-& = etc. out of my Line Numbers.
After that it works.
I saw at your Screenshots that you use & in your Liene Number. This could be the source of your Problem.
The Support Team from Autodesk confirmed this and answerd that in Version 2013 this behaviour doesn`t exsist any more.
Regards
Gandalf Marocke
Message 18 of 25
Arch_art
I use 2012 at the moment.
When you said it would have problem with BAD type. Is that means all of lines needs to name that doesn't contain -_= etc. Cos I tested one of the line I had which doesn't have any "BAD" type, it still doesn't give me anything.
Sounds like there is no other way to deal with it at all?
Cheers,
Peggy
Message 19 of 25
Hi Peggy
Thats Right. Line Numbers shouldn`t contain BAD Types Like & . - etc. and it only works if you have all Line Numbers at your Project without Bad Types.
If you got only one Line Number with Bad Types at your Project it doesn`t work
If you got Time try with a new Project.
cheers
Gandalf Marocke
Message 20 of 25
Venkatesan.A
Peggy,
The other way you could generate an ISO is as in attached image (from Project manager itself).
By the way, its strange to know it doesnt work, I even tried once again this morning and had no issues.
Anyway try the below first take a backup of the project and then:
1. Run PnPLocalDataCachePurger.exe tool. This tool is installed on your system while installing either AutoCAD Plant 3D or AutoCAD P&ID to the install root folder (for Windows 7 something like C:\Program Files\Autodesk\AutoCAD Plant 3D 2012). Sometimes the data cache might create such problem.
2.  If that doesnt work try to do a project audit and try regenerating the ISO to see if its working.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
”Boost
