In the SpecEditor when I try to save a Long Description Style, the hard coded default location is on the local C drive. Is it possible to change the location to a network drive so that other users can access this Style?
Solved by jabowabo. Go to Solution.
You can change it via RegEdit. Do a search for 'SpecEditor' and change the path:
