AutoCAD Plant 3D General
samuel.wu
Message 1 of 12 (1,004 Views)
Lined Pipe
1004 Views, 11 Replies
11-29-2010 07:21 PM
How to create the lined Pipe with Spec Editor?
Employee
Ian_Matthew
Message 2 of 12 (905 Views)
Re: Lined Pipe
12-17-2010 05:08 PM in reply to: samuel.wu
Hi Samuel,
There are 4 videos on how to use the Autodesk Plant Design Spec Editor.  They can be found on Plant Exchange under Videos.  The link is here:
http://autocad.autodesk.com/?nd=plant_tips_tutorials
Ian Matthew
Technical Marketing Manager
AEC / Plant Solutions
Autodesk, Inc.
Employee
TomislavGolubovic
Message 3 of 12 (818 Views)
Re: Lined Pipe
01-03-2011 07:15 PM in reply to: Ian_Matthew
The only difference between lined pipe and standard pipe would be the long description. Just make sure the OD of the pipe matches what is required for the spec. There is obviously no need to model the pipe and the lining itself.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
samuel.wu
Message 4 of 12 (798 Views)
Re: Lined Pipe
01-04-2011 05:42 AM in reply to: TomislavGolubovic
I'm very surprise for your reply, do you have created the lined pipe in Plant 3D before? If you not, please do it before you say this.
Employee
TomislavGolubovic
Message 5 of 12 (786 Views)
Re: Lined Pipe
01-04-2011 11:56 AM in reply to: samuel.wu
I have created lined pipe before. You just make the OD from the manufacturers catalog. Change your long description to be "Cement Lined" or "PTFE Lined" or again, whatever it is from the manufacturer.
Eg, DN100 CS Pipe is OD 114.3 and looking at the Tyco catalog quickly, one of their (Ductile Iron to AS Standard) DN100 pipes is OD 122.
For the purpose of plant modelling, you only need the OD, there is no need to model the wall thickness or the lining itself. The long description of the pipe will state what the pipe is and what the lining is.
Tomislav Golubovic
Autodesk, Inc.
samuel.wu
Message 6 of 12 (769 Views)
Re: Lined Pipe
01-04-2011 05:05 PM in reply to: TomislavGolubovic
So, could you please show me the steps one by one?
Employee
Ian_Matthew
Message 7 of 12 (769 Views)
Re: Lined Pipe
01-04-2011 05:08 PM in reply to: samuel.wu
Samuel,
Just to be sure - are you talking lined pipe e.g. PTFE lined or are you talking jacketed pipe (as in pipe within a pipe).  Also what design standards do you usually use?  Imperial, Metric-DIN...
Ian Matthew
Autodesk, Inc.
Employee
TomislavGolubovic
Message 8 of 12 (765 Views)
Re: Lined Pipe
01-04-2011 05:18 PM in reply to: Ian_Matthew
Samuel, have a look at the video's from Ian's link posted previously. There are 4 Cats and Specs video's that show how to create and edit specs for your project.
Just to re-iterate Ian's comment also, do you mean lined pipe or jacketed pipe?
Tomislav Golubovic
Autodesk, Inc.
samuel.wu
Message 9 of 12 (760 Views)
Re: Lined Pipe
01-04-2011 05:45 PM in reply to: TomislavGolubovic
Ian's comment is our wanted.:smileyhappy:
Active Member
dustyray
Message 10 of 12 (463 Views)
Re: Lined Pipe
03-05-2011 02:26 AM in reply to: samuel.wu
I believe Samuel's concern was the lining flange overlap.
Useually 1/4".
How to convey to spec & catalog editor, for correct  dimensions.
1/4" lining
1/8" gasket
1/4" lining
These must be considered in pipe lengths.
Dusty
You are not logged in.
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
