AutoCAD Plant 3D Forum
Lined Pipe
11 REPLIES 11
Message 1 of 12
samuel.wu
2026 Views, 11 Replies
Lined Pipe
How to create the lined Pipe with Spec Editor?
11 REPLIES 11
Message 2 of 12
Ian_Matthew
in reply to: samuel.wu
Hi Samuel,
There are 4 videos on how to use the Autodesk Plant Design Spec Editor.  They can be found on Plant Exchange under Videos.  The link is here:
http://autocad.autodesk.com/?nd=plant_tips_tutorials
Ian Matthew
Technical Marketing Manager
AEC / Plant Solutions
Autodesk, Inc.
Message 3 of 12
The only difference between lined pipe and standard pipe would be the long description. Just make sure the OD of the pipe matches what is required for the spec. There is obviously no need to model the pipe and the lining itself.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 4 of 12
I'm very surprise for your reply, do you have created the lined pipe in Plant 3D before? If you not, please do it before you say this.
Message 5 of 12
I have created lined pipe before. You just make the OD from the manufacturers catalog. Change your long description to be "Cement Lined" or "PTFE Lined" or again, whatever it is from the manufacturer.
Eg, DN100 CS Pipe is OD 114.3 and looking at the Tyco catalog quickly, one of their (Ductile Iron to AS Standard) DN100 pipes is OD 122.
For the purpose of plant modelling, you only need the OD, there is no need to model the wall thickness or the lining itself. The long description of the pipe will state what the pipe is and what the lining is.
Tomislav Golubovic
Autodesk, Inc.
Message 6 of 12
So, could you please show me the steps one by one?
Message 7 of 12
Ian_Matthew
Samuel,
Just to be sure - are you talking lined pipe e.g. PTFE lined or are you talking jacketed pipe (as in pipe within a pipe).  Also what design standards do you usually use?  Imperial, Metric-DIN...
Ian Matthew
Autodesk, Inc.
Message 8 of 12
Samuel, have a look at the video's from Ian's link posted previously. There are 4 Cats and Specs video's that show how to create and edit specs for your project.
Just to re-iterate Ian's comment also, do you mean lined pipe or jacketed pipe?
Tomislav Golubovic
Autodesk, Inc.
Message 9 of 12
Ian's comment is our wanted.Smiley Happy
Message 10 of 12
dustyray
I believe Samuel's concern was the lining flange overlap.
Useually 1/4".
How to convey to spec & catalog editor, for correct  dimensions.
1/4" lining
1/8" gasket
1/4" lining
These must be considered in pipe lengths.
Dusty
Message 11 of 12
in reply to: dustyray
As well, with the current Lined Pipe Spec provided as a library from a third party, the pipes do not connect, nor can I extend them with paired flanges.
Message 12 of 12
TRdesigner82
I know this is an old post but I'm curious if it was ever determined how to handle the lining that wraps around onto the face of the flange. If this isn't considered wouldn't the bolt length be wrong? I would think you could just and the lining thickness to the flange thickness and that would be that. Lining to lining flange connections don't require a gasket either, how was this taken care of?
”Boost
