AutoCAD Plant 3D General
Message 1 of 7 (506 Views)
Line numbers in Plant 3D
506 Views, 6 Replies
05-15-2012 02:27 PM
I have a job where the P&ID's are already drawn in another program and i will be designing in Plant 3D (2013) off of them.
what is the best way to go about inputing line numbers into Plant 3D. for example a typical line number on this job would be PC01-EX-02303-1" (spec-service-number-size). i want to input this info into plant 3D, espically the service, so that i can apply layers by service.
Employee
TomislavGolubovic
Message 2 of 7 (503 Views)
Re: Line numbers in Plant 3D
05-15-2012 04:46 PM in reply to: thebearjed
Are the P&ID's being done in AutoCAD P&ID, but by another company? Or different software altogether?
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Message 3 of 7 (486 Views)
05-16-2012 04:39 AM in reply to: TomislavGolubovic
"I have a job where the P&ID's are already drawn in another program"
Employee
TomislavGolubovic
Message 4 of 7 (468 Views)
05-17-2012 12:27 AM in reply to: thebearjed
Sorry, don't know how I missed that.
I would just setup the annotation to be the same as the P&ID, and then you can define each of the entries separately.
Tomislav Golubovic
Message 5 of 7 (416 Views)
06-11-2012 12:02 PM in reply to: TomislavGolubovic
for the life of me i can't get to aquire the Service without doing an override which is not optimal.
Active Contributor
jwrampe
Message 6 of 7 (388 Views)
06-19-2012 07:55 AM in reply to: thebearjed
Don't know if you have this answered...
I've had to do this before.  I didn't figure out how to use the built in "Service" property in the way you'd like, so I just created another property (FluidCode since our PIDs were from SmartPlant) and propagated the information that way, then told P3D to layer by FluidCode.  You shouldn't have an issue with setting up the tag structure to use the new property.
It seems we don't have much control over the "service" property unless it's through PID.  Bypassing it made the most sense at the time, but that was on 2011 software.
Valued Contributor
Message 7 of 7 (365 Views)
06-24-2012 11:44 AM in reply to: thebearjed
You can edit the Service in P3D through DATA Manager, see attached procedure for more info
Peter Jansoone
Plant Design software consultant at Greenock CAD service
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
