I noticed that when assigning line numbers and valve tags to components that have copied, these tags and numbers are not kept. After assigning, the component(s) will display the correct tag & number but later the same components will revert back to the properties of the original copied components and/or display as unassigned.
Can anyone help with this issue?
I have the same issue sometimes, does your program crash as well? I find that if it has to be recovered then the pipe I've added since the last save losses its line number. But I have also had problems with line numbers just disappearing. this does not only happen when i copy, I have actually stopped copying pipe and valves all together becuase of this problem, but happens at random...If anyone knows why this is happening please post.
Roman,
We had the same thing with 2011. It occurred when we run isogen. Maybe the tag / linenumber is double in the project. And with generating isos, he sees the same object on the same coordinate somehow and then he disconnects or change the linenumber to nothing....
Its a big problem overhere too !!
Do not know if they solved it in 2012. But do not use the save as function to create study models.... Linenumbers are doubled that way, and isogen looks per linenumber through the hole project....Isogen sees double
Eric
I'm not to ISOs yet. I know that will be a big issue if the line numbers and tags are changing on their own or switching to unassigned after they are set to the correct number.
I'm running Plant 2011. The tags and line numbers are unique to each line segment.
Roman
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Loosing-line-number/m-p/2831117#M1622
Since upgrading to a proper SQL database, all tags / line# assignments have remained stable
