The situation is where i have a 3D drawing with pipes and structures and i need to add some valves. All the pipes has got a Line numbers and now need a special Tag for valves. Valve should take a pipe Line number automatically (wich is working) and now i need to add some information (valve number) manually to Tag. If i do that, the automatically added pipe Line number will be lost? Is there any options to solve this problem? I know that i can change pipe line number back in properties, buts its extra work and it takes time.
I added some descriptions below.
New tag format.
Added Valve on pipe, all is ok, at the moment.
Added number for valve and pipe line number is gone?
Tarmo
Solved by batone79. Go to Solution.
I Can not see your first picture where you configure Valve Tag.
See my picture thats Work for me.
Thanks.
Actually the problem was that Plant uses by deafault Target object > Pipe Line number property in Tag. If i changed that to P3d Line Group. Line Group Number, then all is woking fine.
Thanks batone
