AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Line Number format in Iso
5 REPLIES 5
cpambo
4512 Views, 5 Replies
Hi, I'm trying to set up the format for the line number.  I've already done it in the TagFormatName but when I generate the isometric it keeps on putting extra fields.  Example: my TagFormatName is <Size>-<Service>-<Spec>-<Number> but the isometric callout has added "-<Size>-<Spec>" after my TagFormatName.  How can I take it off?
Thanks in advance!
cpambo
5 REPLIES 5
Rich.O.3d
in reply to: cpambo
you want to look at the tag annotations (to the right of where you set the tag format under the 'P3d Line Group' node...go to the 'Pipe Run Component' node)
I think that you may be using this one...Line Number Callout [Line Number Tag]
try this one...Full Line Number Callout [Size-Line Number Tag-Spec]
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
cpambo
in reply to: Rich.O.3d
That did it!
Thanks for the help, richos69.
neonade
Hello Richos,
Is this applicable on isometric drawings generated.
I think this is the tag for generated ortho drawings.
neonade
in reply to: cpambo
Tags (1)
i can't find that options in my Project Setup.
Please, can you post a screenshot of your Project Setup??
Thanks!
”Boost
