AutoCAD Plant 3D General
Message 1 of 3 (374 Views)
Lap Joint Flange???
374 Views, 2 Replies
07-02-2012 08:59 AM
i have a spec which contains Lap Joint Flanges (stub ins) and for some reason only the 4" size is giving me problems. Going from a 4" pump nozzle to a 4" vessel nozzle i can not get it all connected. i keep getting the "AUTOROUTING CANNOT FIND ANY PATHS" error.
i tred placing all the fittings and pipe with out usinig autoroute but to no avail.
Message 2 of 3 (374 Views)
Re: Lap Joint Flange???
07-02-2012 09:18 AM in reply to: thebearjed
come to find out the pump nozzle was .00001742" lower than the tank nozzle. this is a bit ridiclous, we are not building the space shuttle here. there must be some way to tell the program to round to the nearest 1/16" or so.
Active Member
MarcVandezande8783
Message 3 of 3 (343 Views)
07-04-2012 07:28 AM in reply to: thebearjed
I think the problem still exists in plant 3D 2013: I sometimes get the same error and when I measure I see that there is a difference of .000000782 mm. Yes Milimeters ! There should be a way of configuring how accurate this gap can or may be.
Maybe for version 2014 ??????
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
