AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Joint error
0 REPLIES 0
Message 1 of 1
philipmorais
501 Views, 0 Replies
Joint error
I have a problem with a spec I created for flanged connections as the connection settings of the project, together, set screws, the flange face and pressure class is correct  but  when I try to create a route through equipment for example, appears an error message (see attached).
How could I solve this problem?
Thank you !,
Philip Morais
0 REPLIES 0
”Boost
