AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Jerky Mouse
2 REPLIES 2
459 Views, 2 Replies
Jerky Mouse
Working in project with Plant 3D and my mouse is very jerky when I move. However when I hold down the shift key to disable ortho, the mouse works like it should. The mouse was working great yesterday. Any suggestions?
2 REPLIES 2
We have discovered that when we toggle the "Selection Cycling" off, the mouse works like it should. When we toggle it on, the mouse becomes jerky again. ???
jason.drew
I have ran into the same issue as well. It seems the selection cycling takes some time to "poll" the objects in the drawing when the mouse cursor moves over them. The Plant 3D objects are much more complex, as opposed to standard 2D cad objects, so there is a delay.
Plant 3D also slows down quite a bit when dynamic input is turned on. I usually only enable dynamic input when placing valves or inline components.
Jason Drew
Designated Support Specialist
”Boost
