AutoCAD Plant 3D General
followsea
Message 1 of 4 (482 Views)
Isometrics Issues: Several components are merged into one row in BOM
482 Views, 3 Replies
09-24-2012 08:35 AM
I encountered a problem when generating isometrics:
 Several components with same type and different size  are merged into one row in BOM,  and are  gived the same item number, Quatity is the sum of all.
Above I use "Long description (Family)" for the <description> field in the table. After I Change it to "Long description (Size)" , then it becames:
This time the PIPES are correct, but FITTINGS/FLANGES/VALVES are still not.
I Found that this happens only when I use  specs built by myself(Such as Spec base on GB Catalogue), When I model the same pipes with Specs come with the software, it will be allright. Below is  the BOM appears modeling by Spec CS150:
Then it's no problem.
Any one know why? This problem is annoying me and my colleagues very  much. So many Isometric drawings must be  amended by hand!
P3D 2012 and P3D 2013 have the same problem.
PS: Searching the forum found that others have the same problem, but there's no resolution untill now.
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/ISO-configuration-issues/m-p/3267102/highlight/true#M...
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/BOM-Need-for-every-size-an-own-pos-no/m-p/3609146/hig...
PCFs:
Valued Contributor
neonade
Message 2 of 4 (409 Views)
Re: Isometrics Issues: Several components are merged into one row in BOM
09-30-2012 07:54 PM in reply to: followsea
This seems to be strange.Seems working ok with my Plant3d 2013.
Could you post your specs so that I can use it.
Distinguished Contributor
Arun_Kumar_K
Message 3 of 4 (376 Views)
10-05-2012 08:49 AM in reply to: neonade
You might have specified the Item code for the above items same in you custom spec, that would have caused this issue.
Please check your spec again.
followsea
Message 4 of 4 (320 Views)
10-12-2012 05:24 AM in reply to: Arun_Kumar_K
The itemcode of all the spec is blank.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
