AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometrics I would like divide "Cut Piece List" in two Tables.
4 REPLIES 4
batone79
537 Views, 4 Replies
Hi to everyone..
There are any possibility to divide the same "Cut Piece List" y Two little tables in Isometrics Drawings?
I tryed to insert into "Setup Title Block" two "Cut Piece List" in differents areas but it is generated with the same data.
I looking for two "Cut Piece Tables"  with the all information of the Isometric generated but with the "Cut Piece Items" distributed in both tables, to use the minimum space on "Bill of Material"
4 REPLIES 4
PeterQuinn
in reply to: batone79
So you're looking to split it into two columns to better fit it on the paper?
Peter Quinn
Senior Product Manager
batone79
in reply to: PeterQuinn
Yes, I´m looking for Split into two smaller tables with information distributed in both.
cut piece list
ID     Lenght      ND     Comment   l       ID      Lenght      ND       Comment
01     1125       300                       l       05      750         200
03      980        300                       l       06      200         100
04      100        300                       l
                                                     l
                                                     l
Asimo5000
Try playing with the table split settings, not an ISO specific thing, but click on the table in ISO Template and play with the regular autocad table settings
batone79
in reply to: Asimo5000
Yes now works!
You need to move triangle Grip upward to split tablet.
thanks
”Boost
