I'm trying to change some welds to "Field Fit", it works fine on some services but on others I only get the option of "Field" or "Shop", there is no option for "Field Fit". Any ideas why? I'm also having trouble getting Plant 3D to break the iso's where I indicate the "Break points". Any hints/tips on creating Iso's would be greatly appreciated.
Killian
Hi There
This is because of the end type. Only certain end types allow for the Field Fit option. I changed all my Port 2 end types to BV for my flanges so that this option becomes available. It's a pity.
Are you unable to set the welded end of a flange as field fit? Am I understanding the issue correctly? Is this all flanges, or only some types?
The weld between my flange and pipe needs to be a field fit welld. Both of my ports on my pipe are PL. If my flange's end types are set to port1=FL and port2=SO then I do not have the option to change it to a field fir weld, I only have the option of "SHOP" or "FIELD", but if i change the end types of my flange to port1=FL and port2=BV then in my model the "FIELD FIT" option also becomes available. Prior to this I was working with AutoPlant and I was able to change the type of weld no matter what the end types of my flanges (for example) were.
I have attached 2 screen shots to show exactly what I mean.
I have figured out how to add in the Field Fit option. It is all done through the "Project Setup" dialogue box. I navigated to "Plant 3D DWG settings>Plant 3D Class Definitions>Piping and Equipment>Fasteners>Slip On", from there I went to the "Shop_Field" row and changed the default value column From ShopFieldTypes to WeldShopFieldTypes (see attached image). This then gave me the option of Field_Fit in my Model for the specific connector. Unfortunately it does not come through in my Iso with the FFW as well as the correct symbol on the connection. This issue has been logged with Autodesks developement team and hopefully a solution will be provided soon.
Tarryn
Did you change the skey for the slip on?
Also, the isoconfig.xml will put in the FFW if the type of the item is: FieldFitWeld, so you may want to modify the Content Iso Symbol Definitions to something like TYPE=FieldFitWeld and it should get called out.
Hi Dave
I didnt change the SKEY. The person I was dealing with at Autdesk came back saying that they were able to re create the issue and it is a bug and has been handed on to the developement team. I havent heard anything since.
Are you saying that because I changed the "Shop_Field" property I need to now change the SKEY and then change the Content Iso Symbol as well?
Tarryn
No, I'm saying that if you want the slip on to be called out as FFW, putting TYPE=FieldFitWeld in the content iso symbol definition will do. The bug is probably that the correct type is not set when the property changes.
Hi Dave
Could you give me an example?
I changed the Iso Symbol Type to FieldFitWeld and then when I pulled an Iso the Flange wouldnt come through because it wasnt recognised.
Am I changing the wrong thing?
Can you post a screenshot of what you changed?
This is still an issue in 2016. I thought the developemnt team was working on a fix back in 2012. Is there a better work around than described in this thread?
