Hello
I'm using Plant3D 2012 German
The BOM of an isometric shows me the ND for an bolt set, converted wrongly from inch, like this
24x3940 (7/8"x355mm)
Can I suppress the output or converting of the ND for a bolt set.#
Guido
Pour avoir les bolt set = 7/8"x355mm.
Il faut lors de la création du projet:
Dans: Specify unit settings
- "Specify the base unit for project drawings": Choose "Metric" and then "Inches "Mixed Metric" and not "milimeters"
Regard
Michel
OK, merci
but now I've got 7/8"x3940
And can I change the settings for the units in an existing project?
Guido
