AutoCAD Plant 3D Forum
Isometric drawing info
2 REPLIES 2
391 Views, 2 Replies
How would I remove the following from showing up.
-The NPS of a pipe, fitting or valve.
-Any dimensions that do not have a length of pipe. (ie I do not need to know the height of an olet on top of a pipe, or the measurement of a flange and elbow.
-Any component that is part of another line number
2 REPLIES 2
TomislavGolubovic
For the 'other component' part of your question, if you do a Production Iso and pick a line number, it shouldn't be putting parts of another line number on it. If it is, I would check the part in the model and see what line number is assigned to it.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
in reply to: TomislavGolubovic
They are assigned to different line numbers. The other line shows up as dashed lines, indicating it is a separate line, but I do not see the point in it being on the drawing and would like it to be removed.
”Boost
