AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Isometric drawing control
7 REPLIES 7
Message 1 of 8
diacreek
1250 Views, 7 Replies
When I do prodcution iso drawing generation, all the lines with the same line number in the project have been called out and processed although they are located in various files.
How to control to generate isometric drawings with lines only within the current file?
Diacreek Engineering
7 REPLIES 7
Message 2 of 8
In the Iso generation dialog box, there are three buttons at the top, one of them is for the whole project, another one is for the current drawing.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 3 of 8
in reply to: TomislavGolubovic
 Not the answers!
Message 4 of 8
TomislavGolubovic
How so?
Tomislav Golubovic
Autodesk, Inc.
Message 5 of 8
Hi Guys
I have same problem when I tried to create isometric in the only drawing it generate isometric for the same line number for entire project any solution?
Message 6 of 8
PeterQuinn
You have more than one line in a project with the same line number? Am I misunderstanding this? Isometrics expects that each line number is unique and looks across drawings to find connected parts in other drawings. Maybe you can use the quick iso feature and manually select the components you want on the iso.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Message 7 of 8
dave.wolfe
in reply to: PeterQuinn
Sometimes, users break up the model into skids and the same line number may run in multiple models. Having the ability to run a production iso using only the current drawing parts is something we've had several clients ask for.  Although, I suppose now, since advanced settings are saved, you could define a property that includes the line number + model, and then create isos based on that.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 8
in reply to: dave.wolfe
Hi Dave
Thanks for replay. Where Can I define property for line number+model in Iso running setup? As far I am concerned The only option for run Iso for single drawing would be in the production iso dialog box top left corner (display lines).  am I missing something?
Regards, Samans
”Boost
