When I do prodcution iso drawing generation, all the lines with the same line number in the project have been called out and processed although they are located in various files.
How to control to generate isometric drawings with lines only within the current file?
Diacreek Engineering
Solved by dave.wolfe. Go to Solution.
In the Iso generation dialog box, there are three buttons at the top, one of them is for the whole project, another one is for the current drawing.
How so?
Hi Guys
I have same problem when I tried to create isometric in the only drawing it generate isometric for the same line number for entire project any solution?
Sometimes, users break up the model into skids and the same line number may run in multiple models. Having the ability to run a production iso using only the current drawing parts is something we've had several clients ask for. Although, I suppose now, since advanced settings are saved, you could define a property that includes the line number + model, and then create isos based on that.
Hi Dave
Thanks for replay. Where Can I define property for line number+model in Iso running setup? As far I am concerned The only option for run Iso for single drawing would be in the production iso dialog box top left corner (display lines). am I missing something?
Regards, Samans
